Any suggestions on following series of complex fluid passageways through a part? Wanting to follow the "goes-in-to"s to the "goes-out-of"s.
Could mold flow analysis do this? Just a thought.
---more clarity---
copy surfaces that define fluid passageways into a "dumb" part. treat the passage ways as a part and analyze with mold flow....
not sure if that would do the trick or not...??
What I do is assemble the part into a fake assembly>
Insert a part called fluid into the fake assembly>
Edit> Component Operations> Cut Out
If you select fluid as the cutout part and the passage part as the reference, you can then open the fluid part for visualization.
This is also an extremely good way to then have a fluid part to insert into CFD without any model prep.
In Reply to Andrew Kelly:
