This is somewhat of a rantwith hope that someone has some magic they will share...
I have a nine page drawing of an overmolded componentwith about 500 ordinate dimensions.We are moving the originfrom a verticle tube to a horizontal hole due to, e'hem...past failures and lackof GD&T knowledge. The dims are shown, but for numerous reasons (multiple PG's, ECG's across skel's and master models) I can'tmerely move my 0,0,0 to my new datum location.
Does anyone know a way to trick Mr. Pro/Detail to temporarily forget the old baseline, allow me to set a new baseline and all the dims magically revise? Hmmmm...say it's possible! I do not look forward to re-dimensioning the whole drawing.
thanks....
Found this paragraph in the help:
http://www.ptc.com/WCMS/files/35975/en/35975en_file1.pdf
If an existing ordinate dimension is no longer valid in a modified drawing,
you can edit its attachment instead of re-creating it. Ordinate dimension groups can also be
deleted by selecting only the baseline and deleting it.
In Reply to Dean Long:
thanks....
