What is meant by Explicit Modeling?
Not applicable
What is this good for? Is it a special feature? Is it implemented in this version? Or is it just a module that comes with the full version?
Re: What is meant by Explicit Modeling?
Explicit Modeling is the basic concept behind OneSpace Modeling and its a unique approach in the market Most other 3D modelers are paramteric, that means design intent is captured in the Modeling file, whenever you modify the 3D geometry, it depends on the design intent, wherther that is possible or not. The disadvantage of parametric modeling is, that you must plan any future modifications right from the beginning, when you design your model. In contrast, Explicit Modeling is not based on capturing design intent and you can do modifications whenever you need to make them (Very often design changes are required very late in the design process, in order to follow-up late customer requests) You can find more information about the difference Explicit Modeling provides at the CoCreate website (e.g. look at the webcasts)
