Please add in all text entry locations including parameters, the ability to paste text as All Capital Letters.
Very time consuming having to retype text instead of just copying and pasting in notes, parameters, anywhere text is used or typed.
Don Anderson
As a work around, you can use NOTEPAD ++ (or a similar editor).
You can past the text into NOTEPAD ++, use CTRL-A to select all the text, and then CTRL-SHIFT-U to switch all the text to upper case. Then cut and paste the all uppercase notes into Creo Parametric. This is obviously extra work, but it can be faster than retyping in many cases.
Taking your request a step further, perhaps having the paste menu item be a fly out (like the info menu pick you have shown), with options like UPPER CASE, LOWER CASE, MERGE FORMATS, etc.
Dan N.
