Hello,I designed a sheet metal part,but a flat wall feature can't be unbend,picture follows,I want to know the reason.Help me please,everyone.
For some reason, the accuracy of your model is set too low.
If you go to
File --> Prepare --> Model Properties --> change Accuracy --> set to absolute and to a low value (I've set it to 0.02)
Now everything works like a charm.
If you go to
