Wildfire 3.0 Mechanica Results Display Issue
Highlighted
Newbie
All,
If you are running Pro/ENGINEER Mechanica Wildfire 3.0 please be aware
of the following TAN -
https://www.ptc.com/appserver/cs/view/solution.jsp?n=133743
<https: www.ptc.com=" appserver=" cs=" view=" solution.jsp?n="133743"> . The TAN
is posted next to downloadable WF 3 builds as well as on the main
Technical Support page.
This issue affects Mechanica models with multiple loadsets whose loadset
names have been changed. In these instances when in post-processing
loadsets are selected the results may not correspond to the selected
loadset. If default loadset naming is used the issue does not appear.
This problem is addressed in the M030; which will be available for
download at the beginning of next week.
We sincerely regret any inconvenience this may have caused,
John
John Buchowski
Director Simulation Products
PTC Product Management
Main 408-764-8500
Direct 408-764-8710
Fax 408-764-8700
<http: www.ptc.com=" solutions=" business=" index.htm=">
LiveWorx Call For Papers Happening Now!
