Yes,
Edit > Setup > Mass Props
Change the pull-down menu from Geometry to Geometry and Parameters
Pick the Edit button.
Enter the weight in the Mass field.
Pick the OK button.
Now when you pick Generate Report you'll see the value you entered.
Apparently the value entered through Edit > Setup > Mass Props is the Alternate Mass Prop, rather than the Reported Mass Prop. You'll have to go through a bit of extra shenanigans if you want the value reported in Analysis > Model > Mass Properties to show the entered value. This becomes important if, for example, you're using a format that is pulling a weight from the the Reported Mass Prop (pro_mp_mass)
Go to your assigned material and remove the density.
Enter this in your relations:
for the Mass Prop to calculate the weight? Some vendor parts we download
are not solid therefore the calculation from the density is not
accurate.
Steve
