approach path fails HELP!
al204
Hello Proe CAM users...
I have created a volume sequence (using a milling window). I have tried creating an approach path by setting an axis in the middle of the cavity, and using that as a reference for the approach. Unfortunately the axis is being ignored (no reason given). This would be the approach for every slice.
If an approach path is set, is it necessary to set the exit path as well? is this the reason why it is being ignored?
HELP
thanks, regards
AL.
0 REPLIES 0
