axis pattern
SOLVED
Re: axis pattern
Another way would be to create a offset coordinate system with planes for the geometry and using the rotation angles of the coordinate system.
Re: axis pattern
Yeah, I tried to used the coordinate system rotation angles, and it wasn't working.
The way the part is shown by the o.p., the rotation is to happen first about the default y (green axis) and then about the default x (red axis).
Took me a while to figure out to figure out that I was not being aware of the order of rotations when offset coordinate system is transformed (first x, then y, then z rotation are applied to generate the new csys):
Re: axis pattern
Thank you !!!
