hi everyone
can you help me please
I have two bevel gear and another medium part
when I put another part (gear contact )is failed
anyone can you tell me how I can fix it
I think it is because ground put I dont know how I can fixed it
if anyone can not understand
what I want I can explain more
thank you for try to help me
In general, I do not open RAR files. ZIPs are fine.
I have noticed that in some cases, the gear assignment is orientation sensitive so it may be looking for parallel axes for spur gears.
There may be some other limitations that keep bevel gears from being recognized.
You can try the generic type and user defined ratio assignment.
thank you alot
