I am trying to run a simulation on a bolted joint and I have attached it. I keep getting errors and any help is appreciated. The bolts were represented as volumes because I am interested about the stress in the bolts due to pre-loading. Later on I want to analyze the bolts with a tightening torque load and embedding, but I am not sure how to due the embedding. I did not model the actual threads but the threaded part is connected with simple springs and weighted links. I think the model is failing due to something with the weighted links. I applied a pre-load by creating a volume feature in the bolt. I dont know if I should apply a thermal load on the bolt.
Any help would be greatly appreciated.
As a reference I was trying to use the techniques from user Roland Jakel's presentation on bolted connections.
Hey thank you for responding. Yea I know I can use advanced fastener to get the stresses, but this was more so for learning. I wanted to be able to do more complicated analysis in the future and this was my attempt at taking something "simple" to try and learn. I actually referenced the presentation from Roland Jakel that you had posted in this community to get some of my ideas for constraining the fasterners.
