Hi, is it possible to create a closed datum curve with an ibl-file?? If I change the header from Open to Closed, the result stays an open curve Here's the contents of my ibl-file:
5808e22e50
Thanks! Regards, Jaap This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Hi, Thanks!! ...But that doesn't result in a tangent closed curve... I also tried switching the 2 last coordinates, but that doesn't help either Any more clues? Kind regards, Jaap
Hi Jaap, my first try was: 1. Create a pts file with following points 1 3 0 3 4 0 5 8 0 7 19 0 9 40 0 11 100 0 1 3 0 2. Create a datum curve->from file But the curve looks very awful. Regards, Jürgen
Jaap, It's an extra step, but if you import your points into a Datum Point Feature, then Sketch a Spline through the points, you can close it tangent and easily by picking the points in order and the first point a second time. David
Hi, thanks for the suggestion! The problem is that we have appr. 40 CAD users, both experienced and unexperienced; the curves we will be importing will often be complex, with hundreds of points... Kind regards, Jaap
