composite datum curve and surface transform in WF 2.0 --summary
Newbie
Thanks to all responders.
The answers are:
You may be selecting the three curves with the ctrl key making three
chains when in fact you need to be creating one chain. This is how it
works in Wildfire 1.0
Select the first edge hold shift before you move the mouse, query
through until the option is one-by-one, reselect the first chain and use
shift to select other chains.
Something came through the Knowledge base monitor notification on this
for Wildfire so there is a Tan, technical application note in the
Knowledge base.
