copy geometry "open base"
Highlighted
Regular Member
From what Ive learned the "copy geometry" method has kind of replaced the "merge/Inheritance" method.
When using merge/inheritance in a Creo model, it's easy to open the skeleton model by selecting "open base" in the modeltree (right click on the skeleton feature).
With published geometry I dont have that option which often makes it tiresome to open the skeleton model. WHY IS THIS?
