cosmetic thread
SOLVED
cosmetic thread
Hi, I've made a cosmetic thread on special screws.
But I can not see it.
Any layer is hide.
I would like to use end of thread (family table drived) as a plane.
Is it possible ?
Re: cosmetic thread
Dominique,
  • cylinders / holes with and w/o threads do not look different.
    • Change view style to hidden line and see if the thread does exist
      • I personally indicate threads by painting holes/cylinders /neon green/
  • For plane offset, please use relation - offset plane by threaded length.
Regards!
Re: cosmetic thread
Dominique,
Regards!
Re: cosmetic thread
Thanks a lot,
So I've managed this as you suggested with a datum plane an relation.
But it's strange that it seems not to be possible to see thread.
All layers are set as visible...
