cosmetic threaded holes in drawing for wildfire 3.0
SOLVED
Newbie
I'm having a problem figuring what I should do for a part that the thread blends through the part. I attached some jpeg of what I'm talking about. Please help.
1 ACCEPTED SOLUTION
Highlighted
Re: cosmetic threaded holes in drawing for wildfire 3.0
Can't remember the exact version that fixed this issue in the hole feature (maybe WF 4.0. Now when you create a new hole the cosmetic thread is handled correclty with no additional action. If a new hole in WF 3.0 does not come in correctly you need to trim the sufrace, or create the cosmetic thread separate from the hole and you can choose "up to surface" for the depth.
2 REPLIES 2
Highlighted
how do you do trim in drawing
LiveWorx Call For Papers Happening Now!
