Hi alls,
Since I'm using Creo3; I can't create flat state from a sheetmetal part.
On Creo2, it was very simple...
What I'm not understanding ???
Go to File>Options>Configuration Editor and set enable_flat_state to yes. Then go to File>Prepare>Model Properties and click change next to flat state instances. Then set up your flat state, which will create a family table for you with a flat and fully formed state.
thanks a lot 😉
