creo notebook + graph feature
ja1
Is it possible to use graph feature in the Creo Notebook?
1 ACCEPTED SOLUTION
ja1
(To:dschenken)
I have tabulated data and want to use
y=evalgraph("TT", x)
in relation at notebook level to calculate global variables and next for using in assembly. That assembly has been declared to notebook.
As alternative, I can create evalgraph at assembly level and it works perfectly, but I cannot bring calculated value to be visible in notebook.
ja1
(To:ja1)
Simply, I cannot find graph feature in creo notebook.
On the other hand, creating graph feature at assembly levels don't bring calculated parameters to see at notebook level.
dschenken
(To:ja1)
As far as I know there are no features in Notebook. Notebook is intended to be a source of information, not a recipient.
You may be able to do what you want with a skeleton part, but you'll have to explain the problem you are trying to solve.
ja1
(To:dschenken)
