decal edit
scollins
decal edit
Decal - sometimes the 'eyedropper' will activate & other instances it will not activate.  The decal image *.jpg or *.png will populate, but I can't seem to activate/edit for "parametric/planar/re-sizing" etc.
I've tried create new color on primary surf then ctrl-c, ctrl-v & apply to surf.  Either way, no dice..ideas..
Thanks for your time,
Sean
mbonka
(To:scollins)
Hello Sean Collins
see "Model appearances editor" upper right corner. There is a "dropper" which is using for decal, color texture and bump editing.
1. click dropper icon
2. select desired surface
3. decal editing button should be active
Hope it can helps...
Regards
Milan Bonka
