Can you draft walls in creo-2 that have radii on them without taking off the radii? I have a dummy part we got from a customer and it has a lot of ribs on it and they all have radius on them. They want the draft changed but i can't get the native creo file for some reason. Is there a way to change this draft with out taking the radii off?
If you can't get the native Pro/E file you're kind of hosed. Without sactually seeing the geometry it's hard to advise.
maybe the feature recognition tool can remove the radii. You enable it by frt_enabled yes in your cofig.pro.
Reinhard
This may be a helpful link if you choose to go in the direction Reinhard has suggested:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS58453&lang=en_US
