I have a setup that I built for first article inspection. I built a table and populated it with the parameters from the part model. We also have a drawing built from the part as well. The problem I am having now is that if I try to check in the drawing the model will pull with it but not the inspection sheet. If I try to check in the inspection sheet, the drawing will not check in. How can I tie both to the model so they will all link and check in? I hated to do the inspection sheets over again and use an instance but I don't know how else to do it?
