extrude up to multiple surfaces
SOLVED
Newbie
Is there a way to extrude a feature up to a surface created by two planes? I created a surface which looks like a V in the top plane, and then tried to extrude up to this surface, but it will only extrude up to one of the planes. I would like to complete the extrude using only 1 extrude, not come back and trim or do aother extruded cut. See attached file for what I was able to do. Thanks
1 ACCEPTED SOLUTION
Re: extrude up to multiple surfaces
You can try this:
When defining side, select the surface as quilt (Set Quilt in smart filter).
Result will be:
You can try this:
Result will be:
Thanks, that is exactly what I wanted.
Glad to help you Steve.
Does the "Quilt" have to be a surface or could it be existing solid geometry?
