flat pattern with one click
Highlighted
Contributor
heloo
i have a question what happen in min 5:45 https://www.youtube.com/watch?v=oUg7LEA7GAM
when insert flat pattern
what is explication ,i am interested
This video will help you to add flat pattern dimension for all the instances of a sheet metal part, at a time in Creo Parametric. Difference between Two-D an...
4 REPLIES 4
Re: flat pattern with one click
You might expand on your question.  What I see at 5:45, it is a quick wrap up.
Highlighted
hallo
what i need ?
the dxf fille without many operations
i create a template with top left and front but my grand problem is how create and flatt pattern in same drawing and export it
i hear is posible with combined view but i dont n know how do it
in solidworks i have flat pattern with one click in export
any help is a now thing for my 🙂
have a nice day
Highlighted
hallo
what i need ?
have a nice day
Highlighted
The normal flat pattern routine in Creo will also make a flat pattern with one button in the sheetmetal model.
It also makes what you need for a flat pattern in the drawing.
There are other ways, but this is the way that PTC intended.
