Dear All,
what is the work of the option given in the sheet metal hole wizard .. Hole geometry representation light weight on and off ?
Manish
Creo is not built to run on OS-X. It is only available for the different Windows flavours.
You can still run it on a Mac probably, but then you need to use a tool that allows you to run Windows software on your Mac. Here are some possible ways of doing that: http://www.howtogeek.com/187359/5-ways-to-run-windows-software-on-a-mac/
