hole position tolerance
Participant
I have this hole on the right that I use for a retaining pin.  My vendor has started drilling them crooked.  I would like to constrain it to be parallel with the axis through the vertical center line of the larger hole.
Is there a proper geometric tolerance to use for this?  The parallel tolerance does not seem to cover this.
T
12 REPLIES 12
Re: hole position tolerance
True position hold position and angularity
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
How is the angle captured then since there is no datum through the vertical axis used for the angular dimension?
You can't specify the vertical portion of a centerline as a datum.
The large hole in your part is the same as the 80.2/80.0 dimension [-B-]. The "into the page" dimension is to the [-A-] datum.
The small hole axis would have to remain within the diametrical tolerance for the entire distance which through the part which is how true position controls angularity.
Steve Williams
So would I create a datum on my diameter as well as the top surface of the part similar to the first drawing you show?
You really need to look at it from a functional standpoint. Important stuff will be your datums.
On your part, since you are dimensioning to the larger hole, I'm assuming that is important to the smaller cross hole. So I would make that a datum (A or ??) and your in to plane dimension, I assume is from somewhere important so I would make that a datum (B or ??). The dimensions from those datums to your cross hole to position it would be basic dimensions. Those basic dimensions are toleranced by the GTOL and control the axis of the hole. The entire axis must stay within the tolerance as shown in the second image or interpretation, the axis of each hole stays within the tolerance zone.
It gives you the ability to inspect the length of the axis and control the drill angle, in this case 90°.
Steve Williams
And I hope someone chimes in if I'm saying something incorrectly or giving a poor explanation. Sometimes I miss important points!!
Steve Williams
Stephen is correct with having to look at if from a functional standpoint.
The creation of datums "just to create" them should be avoided unless they make sense to group a set of features together functionally.
it looks like there is more to this part.  If there are datums already established, try to use them first.
you can re-order your datum importance to the feature to control specific requirements, like perpendicularity and position.
Not knowing if your part is square or round will change how one can apply proper Geometric Dimensioning and Tolerancing (GD&T).  Having a round part, there is already two "datums" inherently established, but with a square part, for example, three should be created to control all directions.
To "stab" at this fundamentally, location to the cross hole should be basic, all directions.  The size of the hole will be determined by your fit requirement.  The positional tolerance will need to be calculated or "stacked" - what can you allow for locational deviation.  this is not only how close or far you are from the assumed piece your are trying to pin (axis to axis), the fit of this assumed piece within its bore, and space within the assumed piece to allow the pin space so the part can be captured.  once you know this, it will give you a good indication of what kind of "positional" location you are needing.
select the datums, if you are going to use position, according to: first; direction of the feature or "Z", then location XY or YX.  Z will control perpendicularity; XY - location.
A class in ASME Y14.5 might also be helpful.
Thanx Ron. That class is on my list to take this year.  It is a bit confusing when you don't have all the background.
Regarding other datums and such,  I guess I don't know why a datum on the other side of the part would even be relevant.  There are not existing datums on this port (maybe there should be?) The issue I have is that my vendor started drilling these holes at an angle, which made the retaining pin jam into the inserted part.  I need to define the pin hole location so that it will be parallel to the port hole and is center line is tangent to the bore of the port hole. I agree that a position tolerance is what should be used, but that is tied to a datum somewhere and the only thing I care about is its relation to this hole, not the rest of the part.
For more perspective, here is a 3D view with the pin hole in red.  We place a cylindrical part in this port and then retain it with the pin. There is an o-ring at the bottom, so when the hole is off, it separates the inserted part from this 'body' and causes a leak.
Anthony,
When you understand the fundamentals of GD&T, I think you will self answer your questions and perhaps understand the full ramifications of the information I provided.
Another thing I don't know is: are you making onesy twosy of these or millions.  that will change dimensional schemes.  I'm thinking on the lines of small quantity.
But, in the spirit of learning, every datum you set up beyond the first three have to be "qualified".  If you think of it in terms of machining, you will need to do another set-up.
IF the first three datums are good enough to use for this, the establishment of additional datums is not necessary.  Your stack values will determine the need.
IF new datums are needed, then by all means, establish them - but use the KISS theory (Keep It Simple Stupid)  Your data from the stacks will tell you what you need to do.
Each new datum basically "resets" the stack tolerance start back to zero, essentially getting rid of excess tolerance baggage.
I do understand what you are doing.  I did something similar with sleeves in a valve train that were pinned in a valve body housing for automotive transmissions and also with pressure regulators in a hydraulic circuit, pinned for easy removal.
(Looking at the design, suggest a step in the bore so you dont cut the o-ring with the pin groove)
ron
