hole table problem
Highlighted
Newbie
hole table problem
Hi all,
I have trouble making a hole table. Making an axis table works fine, but is
not what I need. When I try hole table, and point at the csys, it says 'no
items found". The holes are all crated as holes. What can I be doing wrong?
WF3
TIA
Sip
Highlighted
RE: hole table problem
If the placement plane of your holes is not the xy plane of your cys, then the table will not list those holes.
Hope this helps.
