how do you remove quilts from drawing section cut?
Newbie
How do you remove quilts from a drawing section cut?
Re: how do you remove quilts from drawing section cut?
You might give this a read;
Hide cosmetics in drw
If that doesn't answer your question, please expand on your issue.
...and welcome to the forum, Robert!
If we're talking about the same thing, you'll need to make sure you check the box for "include quilts" when you are defining the section under the model tab in the feature. Once you do that, your section will also cut through quilts....otherwise you can just hide them in the drawing layer tree.
