Hello everyone,
any buddy guide me how to make drawing attached file part in Creo 3?
kind regards,
Adnan
Hi Adnan,
Open the iges file in Creo and save as a new file. *NOTE, when opening, you will need to change the TYPE to All in the open box to see the required file. Then create a drawing, if you use the same file name, it will pull the part into the drawing automatically. Add views to the drawing as you would anything.
Hope that helps.
