how to flatpattern a elbow in sheetmetal
adeshmukh
3-Visitor
i want to flat a elbow in sheetmetal to measured it's development length?
BenLoosli
(To:adeshmukh)
Sheetmetal only works on sheet types of parts, not tubes.
Your best bet is to appriximate the elbow as a sheetmetal part and flatte that.
BenLoosli
(To:adeshmukh)
Akshay, you need to give us more detail. Is the elbow a rectangular cross section? Circular? If it's not designed for a certain way, then you will have to stretch the material when you form the flat pattern into an elbow. Calculating the allowable stretch is not something Creo can do.
it's circular section.
Also I have to show bending lines in part as well as in drafting
**Confirming Ben's response and marking as such.
