how to improve 3D modeling of circle
ptc-5882915
1-Newbie
I find out that going fron a circle in 2D to 3D structure the arc definition is not really good. Do i need to use the Spline tool to rebuild the entire circle or there is another way.
PS: sorry for my english, i am french.
thanks
12 REPLIES 12
Inoram
(To:ptc-5882915)
If you sketched with the circle command in the Sketcher and revolve it, it's a circle, it sounds like you might be seeing display quality? Can you post a picture?
cercle.bmpyes
This is due to the conversion from a precise surface definition, which Pro/E maintains, to a faceted representation which the computer graphics card displays. Sometimes just regenerating the model when zoomed up will cause a smoother representation to be made. This will happen even with the spline tool. It doesn't affect the actual smoothness of the surface - a CNC program would make a very smooth curve based on the Pro/E data.
thanks.
Adjust the Facets in the part properties dialog.
The other answers you recieved relate to Creo Parametic.
This question really belongs in one of the areas shown below.
Aniway i found a "combine" trick in french. I used "Modeling - Splines - Canonical Curve" i took my quite a long time, is not prefect, but it's good enough for me.
But it would be nice to have a quicker solution. May be it is because a use miliméter resolution for a raduis of 57 mm.
If you haven't already, it might also help if you set edge display quality to "very high" assuming your hardware has the resources to handle it. (Creo 2.0)
I do not find this options in créo elements/direct modeling 4.0. I have missed something. But i got a free version to prototype an 3D impression.
Bur by the way, Créo is very easy to use, it is a good sooftware. he took me a week to get use to, it is so logical. Great conception "BRAVO"
If not necessary never use splines instead of circles, because you will never have the possibility to change the radius or diameter in future.
The default setting for cylinders is to set ~ 40 facets in the shaded model for the cylindrical face.
But this is only the graphics representation.
This is still a cylindrical face.
You can change the settings.
File / Settings / 3D Object / Part Misc / Graphical Resolution
Defaults is:
set_facet_resolution 36
Best regards
WoHo
ITS ONLY A GRAPHICS DISPLAY ISSUE,Eric Terrell HAS EXACTLY ANSWERED THIS QUESTION,SETTING EDGE DISPLAY QUALITY TO VERY HIGH AND USING MORE POWERFULL GRAPHICS CARD COULD BE MORE BETTER.
Actually, Gary has this correct. It's not regarding Creo and was posted in the wrong forum.
I've moved this discussion into our community.
