how to join different line segment into single line segment ?
Highlighted
Newbie
actually my question is after dividing an line into several sections how to rejoin it again into an single line segment ?
Tags (1)
Highlighted
Re: how to join different line segment into single line segment ?
You don't join line segments. You delete all but one of the pieces and size it (through trimming, or dimensioning) to the length you need.
Highlighted
I am not getting the actual design intent but you can try creating  composite curve. As Ken mentioned you cannot join the line segments, so try getting a new curve. For that select first curve, copy and paste + SHIFT and other curves. This will give you a new curve.
Highlighted
I think this person is talking about line manipulation in the sketcher.
Highlighted
Possibly yes. 🙂
