How could I open or edit a prt file made in creo 2.0 in wildfire 4.0?
If you have installed some software related to the mouse, then try to play with its configuration (in Control Panel) or simply uninstall it.
Martin Hanak
I have encountered this problem many times with Logitech mice (I am assuming that some of the other brands out there might do the same thing), where the middle click has been replaced with another command (once again, with Logitech anyway, they replace the middle click with the "document flip" command; Lenovo touchpads default to "mouse panning"). As Martin suggested above, if you had to install any "extra" software with your mouse, make sure that the middle mouse button is mapped to middle mouse.
