i need to unbend the model
JAK
6-Contributor
6-Contributor
I need to flat or unbend the part,Here i attached the model
SergeyGvozd
(To:JAK)
The deployment of this model by standard means is not possible.
You should create this model from parts. Or use the FTI Fastblank Integration extension.
PTC Creo Parametric & FTI Fastblank Integration for Blank Devlopment
JAK
6-Contributor
6-Contributor
(To:SergeyGvozd)
Thank u so much..I will try and let u know later.
