i need to unbend the model
Regular Member
I need to flat or unbend the part,Here i attached the model
Tags (1)
Re: i need to unbend the model
The deployment of this model by standard means is not possible.
You should create this model from parts. Or use the FTI Fastblank Integration extension.
PTC Creo Parametric & FTI Fastblank Integration for Blank Devlopment
Thank u so much..I will try and let u know later.
