insert Symbol into a cosmetic sketch,
ptc-2798478
1-Newbie
Using WF 5 and I can not figure out how to put a symbol into a cosmetic Sketch. I have to put a regulations stamp on a label and can not get it to work. I have the symbol in sym format. Any help would be great. Casey
2 REPLIES 2
First of all, cosmetic sketches suck. Use a datum curve instead. Second, you can convert the symbol into line entities in a drawing, then you can use sketch, data fromm file, then copy those elements into your model sketch.
Yeah I know they suck Thanks I will try it out. Casey
