insert mode fail
SOLVED
Highlighted
Regular Member
insert mode fail
the insert mode is block
I do not " walking " with the insert between features
please support me
the problem is i am uppdating to creo 4.0
1 ACCEPTED SOLUTION
Re: insert mode fail
I found what part have
It was made mirror with features and this is reason for insert in block
6 REPLIES 6
Did you set your features as read only? You need to remove read only on your features.
The fille isn't read only
It is a fille from old proe
is it a reason ? i don't want to influencing
It is the first time with this strange error
i found on internet a response Smiley Happy
I think this is the right answer  from old filles proe and convert to new creo 4.0
 " DO you mean (in 2001) FEATURE --> INSERT MODE --> ACTIVATE?
and FEATURE --> INSERT MODE --> CANCEL?
You will still need to resume features etc to get back down the model tree.
Is this helpful?
Hope this helps."
I guess your file is from very old version. Regenerate all the features by either using model player or redefine the 1st feature. Try insert feature after that .
Yes is very old version
i try but doesn't work
another problem is the cad fall on modelcheck and it is hard to repair in same mode
