the insert mode is block
I do not " walking " with the insert between features
please support me
the problem is i am uppdating to creo 4.0
I found what part have
It was made mirror with features and this is reason for insert in block
Did you set your features as read only? You need to remove read only on your features.
The fille isn't read only
It is a fille from old proe
is it a reason ? i don't want to influencing
It is the first time with this strange error
i found on internet a response 🙂
I think this is the right answer from old filles proe and convert to new creo 4.0
" DO you mean (in 2001) FEATURE --> INSERT MODE --> ACTIVATE?
and FEATURE --> INSERT MODE --> CANCEL?
You will still need to resume features etc to get back down the model tree.
Is this helpful?
Hope this helps."
Yes is very old version
i try but doesn't work
another problem is the cad fall on modelcheck and it is hard to repair in same mode
