instance
Newbie
instance
I am using wf3. I made two instances of the same sheet metal part. How does one go about deleting one of those instances? thanks.
Nothing serious will happen
Hi, I don't think anything will happen.Just that particular instance will be deleted.But if u have refered that instance in drawing the drawing will fail. And whwnever you do something with instance keep all (drawing & generic part)in the session. Otherwise when you close everything and reopen it will create some problem.
RE: Nothing serious will happen
i don't think you understand. I made a second instance by mistake. I have not done anything with this instance. All I want to know is how to get rid of it. thanks.
Family Table
James, You need to go to #Tools >>Family Table & select the instance you want to delete by #Edit >> Delete Row. Rameet
