modeling spin center
how do i change the spin center to be somewhere on the model instead of out in space?
11 REPLIES 11
RE: modeling spin center
I don't how to or even if you can move the spin center once the part is created. But, if you turn the spin center view off the part will spin around where ever you click. That is click to middle mouse button to spin.
thanks, this works well with my space navigator, i just turn off spin center and then click with middle mouse button to rotate and then that seems to activate the center and the navigator acknowledges it and then uses it as the new center.
Check to see if there's a model datum that's located a fair distance from the geometry. I've ran across a model or 3 that had the spin center off in space like was mentioned and discovered that's the cause.
There are also some options under View>Orientation>Reorient. A dialog box comes up, select preferences from the drop down and you can reposition the spin center if you need or want to. It's limited so you may not be able to get what you want.
View > Orientation > Reorient > Preferences (from the Type pull-down) Now you can choose: Model Center Screen Center Point or Vertex Edge or Axis Co-ordinate System
Re: modeling spin center
Hold down the <ALT> key move cursor over node on model hold down middle buttom mouse and rotate for localised operation.
You can set the spin center in the Orientation dialog.
that doesn't stick session to session though correct?
I don't htink so. It would be nice to lock a spin center permanently. And to select it as the default view center for drawings while we're at it
