hi,
how to open family table instance in Creo View 3.0. can anyone help.
-- Rai
Andy is correct. Your instance needs to have its own viewable. It does not behave like Creo Parametric where you can open the instance from the family table.
Ravi,
I do not believe that it is possible .
Martin Hanak
Are you talking about opening the instance from the pvz of the generic? That case is no. Your instances should have its own pvz file.
