parameter inconsistency in relations
SOLVED
Newbie
I'm currently experimenting with automating many things in Creo 2.0 (M030), and I found a strange behaviour.
When working with parameters, relations and pro/program , a measurement feature of an angle is always shown as degrees.
EXCEPT for relations in a feature. There you need to work with RAD.
It took me a little while to find out why my parts weren't behaving the way I wanted to, but now everything works just fine knowing this.
But what if PTC wants to fix this inconsistency one day? Are all my automated parts corrupt from that day on?
1 ACCEPTED SOLUTION
Re: parameter inconsistency in relations
No, they will add a config.pro options asking if you want to have these features read in radians or degrees with the default set to what it has always been.
