Hi, friends. I created a revolve cut (green). When I tried to pattern it as 4 in 360 degree, different feature shown in rest 3. Need help to fix it. Thanks, Bill
There might be a problem with the reference you choose to make the pattern... wrong axis ?
I agree. I noticed something similar, but more drastic, doing a pattern. I think I made the mistake of using a reference to a plane in the sketch, vs using a horizontal constraint, I'm going to check that. On another note, the geometry pattern of the same feature worked first time with no issues. Hmmmmm......
please upload your model using How to attach file when you Reply to a discussion. procedure.
MH
BH,
I am using Wildfire 5.0 M060. Are you using same one?
Bill
Bill, I am using Creo 2, M130.
I guess the problem can be caused by a bug present in ProE WF5 M060 (version of your sofware). When I delete second pattern a create it once again in CR2 M070, then its geometry is correct.
Unfortunatelly I do not know, how to resolve the problem in ProE WF5 M060. Probably you have to redefine patterned feature and add some references.
MH
I verified that your problem is ProE WF5 M060 bug. You have to use different technique to create the pattern.
Resolution:
MH
I recreated the problem in Creo 3.0 M060. I deleted the pattern and created again, and the problem persist.
It seems to be a problem in the sketch of the revolve feature. Try to modify the sketch, add some centerlines and add an angular reference, also try to edit the dimension and delete some constraints. It should solve your problem. Your sketch should look something like this.
See the sketch in the file attached, a copy/paste operation should be ok.
I am using WF5.0 M060 to re-create, still does not work.
