patterning a feature following a curve.....[summary]
Newbie
I was trying to use some of the new functionality of wildfire and it seems
to have not reached my expectations once again. I ended up using standard
patterning techniques and relations to get what I needed. Here are some of
the responses:
Keep in mind that when patterning along curves in Wildfire (fill patterns),
the spacing is only approximate. Also, as you've discovered, the spacing
value can't be used in relations or fam-tabs. PTC's recommendation is to
use a dimensional pattern instead of the fill pattern
http://www.ptc.com/cs/tpi/117766.htm <http: www.ptc.com=" cs=" tpi=" 117766.htm=">
