Hello and thank you for your attention. This is not the first time i have this issue... it usually happens to me whenever i work in a complex model (maybe a car engine body or motorcycle engine bodies)... The problem is like this: i`m working with a file and suddenly, because of a regeneration or a missing feature or whatever, the program crashes. I just open pro-e again, and try to open the same file... and again, it crashes again. I can do this several times, until i open a versioned file... up to 5 versions older than the last file i was working in!! this is really frustating... sometimes i lost a lot of time, hours of modelling job...because of this error. And there is more: sometimes (only in a few cases) if i open the last version but in geometry representation, i`m able to do it, and then change the representation to master... sometimes i don`t and the program crashes again... I other situations i can load the file in an cnc file, and open it with right clic "open base" command... and it works... but again... not always. sometimes it crashes, the same way., So, sorry for the extension of the explanation... but its not easy to explain what actually happens without a good descrption of the issue. I think is kind of an issue with some feature, or missing references...but instead of showing an information error window, it just crashes. I need assistance from the best people in this forum, cause i assume this is not a common issue. Thank you very much!
