When placing the same part twice, Wildfire 5 was smart enough to remember the constraints from first placement and I just had to select the new faces to constraint the new part to. However, in Creo 2.0 (M080), there seems to be an option to do the same in dashboard, but it's ghosted. Already defined constraints are ignored. Is there a hidden option in the new ribbon menu I did not enable, or is it a known issue in creo 2.0 parametric (M080) ?
Thanks for any pointers .
Regards, Ulrich
Check option "use_temp_interfaces" (or something in that spirit, I do not have Creo handy now to check) is set to Yes . It should not have changed from WF5 to Creo, but we already had a thread with such complaint.
- Vlad
Same issues as top described and the solutions do not work.What a disaster .
