"Save a Copy - Shrinkwrap Type" is not available for me
DCllc
7-Bedrock
I created an assembly of parts comprised of complex boundary blends and want to shrinkwrap the whole thing and make a solid. The option to Save a Copy -> (type) Shrinkwrap (to solidify) is not an option. Shrinkwrap is not an option in the "type" pull down menu. Any thoughts on workarounds or how to fix this?
Thank you!
Best,
DC
StephenW
23-Emerald II
(To:DCllc)
I may be wrong but I don't think shrink wrap will solidify surface geometry. You can test this with a couple of simple models to verify your process will work or not.
In my experience, if you have solid geometry in your parts, you will get he solid option. If you do not have solid geometry, you will not get the solid option.It is not intended to solidify non-solid geometry.
You may be able to solidify the resulting surfaces in the part that is created.
