"Stop Light" - Part Modeling
Highlighted
Topaz II
We recently switched to Creo 4.0. The regeneration "stop light" is on the bottom for our drawings, but I do not see it while in part modeling. Is there a config option that needs to be changed?
Tags (1)
3 REPLIES 3
Re: "Stop Light" - Part Modeling
I raised this point last year. I recieved one reply that did not really answer the question so unless someone tells me any different I guess the answer is no, there is no config option to bring it back. I mainly work with Creo 3 but when i do use Creo 4 I certainly miss the Traffic Light system.
I thought I had remembered seeing a post, but searched to no avail.
The pain is when you go to save and an error message pops up that the part in not regenerated and you can't escape out of the menu to regen and then re-save.
LiveWorx Call For Papers Happening Now!
