relations
ptc-218373
relations
I'm trying to set up relations that automatically generate a material stock code, based on the combination of two other parameters that governmaterial type and thickness. Everything works fine for thicknesses that are listed, but I'm wanting the stock code to display "-" if a thickness is used that doesn't exist in the listing, and it's not working; the stock code doesn't change. The below is a partial listing. Anyone know how to make this work?
IF RAW_MAT_SPEC == "RAW PLATE-44W" & THICK == '2_1/2'
RAW_MAT_STOCK_CODE = "202-015"
ELSE
IF RAW_MAT_SPEC == "RAW PLATE-44W" & THICK == '3'
RAW_MAT_STOCK_CODE = "202-016"
ELSE
IF RAW_MAT_SPEC == "RAW PLATE-44W" & THICK == '3_1/2'
RAW_MAT_STOCK_CODE = "202-017"
ELSE
RAW_MAT_STOCK_CODE = "-"
ENDIF
ENDIF
ENDIF
Thanks in advance,
Dave Tate
Peerless Trailers, Penticton, BC
Dave,
First, initialize in case none of your conditions match. Then make each IF
stand alone.
ENDIF
ENDIF
ENDIF
Alternatively,
IF THICK == '2_1/2'
ENDIF
IF THICK == '3'
ENDIF
IF THICK == '3_1/2'
ENDIF
ENDIF
Bob Monat
Jerand Technical Services, Inc.
bob@jerand.com
www.jerand.com
1-317-875-6087
On Wed, May 23, 2012 at 5:41 PM, David Tate
> govern material type and thickness. Everything works fine for thicknesses
> ELSE
> ELSE
> ELSE
> ENDIF
> ENDIF
> ENDIF
> Thanks in advance,
> Dave Tate
My thanks to those who responded - it turned out that my problem was
caused by a different issue: my relations also include a string
conversion of the real dimension to allow for variations:
IF THICKNESS == .28 | THICKNESS == .281 | THICKNESS == .2813
THICK = '9/32'
ELSE
IF THICKNESS == .313 | THICKNESS == .31 | THICKNESS == .312 |
THICKNESS == .3125
THICK = '5/16'
ELSE
so when the THICKNESS is modified to something that is out of the
listing range, the THICK value would not update. The solution was to
add the line
THICK = '0'
at the beginning of the above range.
Quoting David Tate <davidtate@keystrokedesigns.ca>:
> parameters that govern material type and thickness. Everything works
> ELSE
> ELSE
> ELSE
> ENDIF
> ENDIF
> ENDIF
> Thanks in advance,
> Dave Tate
