same title part and drawing automated
bcat
8-Gravel
hello people
i have a question
i draw a part screw_p2319024
it is posible to make same name in drawing name without type on keyboard same name?
i want when creating drawing file that have the same name as part of Automated
is posible the drawing have name screw_p2319024
5 REPLIES 5
MartinHanak
24-Ruby II
(To:bcat)
Bogdan,
you can use AutoIt. For inspiration see Re: Creo 2.0 - Open a drawing from active part?
Martin Hanak
Martin Hanák
Jose_Costa
6-Contributor
(To:bcat)
Unfortunately, there is no current functionality for this. The following document looks like it might work for you but I'm not sure how practical it is.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS37133
Bogdan,
This works for me and hopefully the same for you.
First off, I received this from nicomajstr, a mcadcentral user.
I requested the original files which ran on WF4 and modified them to work within Creo so the kudo's goes to his (her) effort.
To make this simple, create a folder path:
c:\home\programs
and put the two files attached - unzipped, of course, in the programs folder
once you understand what is happening, you can change the file paths in the script to where you want.
in your config.pro, put this script:
mapkey std @MAPKEY_NAMECreate new drawing with a format;\
mapkey(continued) @MAPKEY_LABEL>Create New Drawing;\
mapkey(continued) ~ Command `ProCmdModelSaveAs` ;~ Open `file_saveas` `type_option`;\
mapkey(continued) ~ Open `file_saveas` `type_option`;\
mapkey(continued) ~ Select `file_saveas` `type_option` 1 `db_563`;\
mapkey(continued) ~ Activate `file_saveas` `Current Dir`;\
mapkey(continued) ~ Activate `file_saveas` `SAB_c:\\home`;\
mapkey(continued) ~ Select `file_saveas` `ph_list.Filelist` 1 `programs`;\
mapkey(continued) ~ Activate `file_saveas` `ph_list.Filelist` 1 `programs`;\
mapkey(continued) ~ Activate `file_saveas` `OK`;~ Activate `shd_img_param` `OK`;\
mapkey(continued) @SYSTEMstart C:\\home\\programs\\ustvari_risbo.bat;\
mapkey(continued) ~ Command `ProCmdRibbonOptionsDlg`;\
mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `ConfigLayout`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `ConfigLayout.Open`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
mapkey(continued) ~ Input `file_open` `opt_EMBED_BROWSER_TB_SAB_LAYOUT` \
mapkey(continued) `C:\\home\\programs\\`;\
mapkey(continued) ~ Activate `file_open` `opt_EMBED_BROWSER_TB_SAB_LAYOUT`;\
mapkey(continued) ~ Command `ProFileSelPushOpen@context_dlg_open_cmd`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;\
mapkey(continued) ~ Activate `UITools Msg Dialog Future` `no`;\
mapkey(continued) %usdrw;.;.;.;.;.;.;.;.;.;.;.;
fire up creo
open an assembly or part that does not have a drawing and run "std"
all the ".:.:" after %usdrw is an auto filler for the drawing form that has parameters. adjust or remove as needed.
enjoy
Hi RonSt. Pierre Marble.
I have a problem with your script. It creates a tiff image with the same name as part file and for the drawing it's asking me to type the name for drw. What i'am doing wrong? I don't understand what i must adjust %usdrw.
