save a view of a cut creo parametric
mn1
Hey there,
I have a step model which is only one part. I would like to cut this model and save on of the parts. I already created a cut so i can see just one part of the modell. But if i save the projekt, the modell is not cut.
Who can I save the cut view?
Thanks for anser.
1 ACCEPTED SOLUTION
Dale_Rosema
(To:mn1)
Start an extrude. It is in the main tool bar.
With assemblies, you can only do an extrude cut (you cannot add material in assemblies).
13 REPLIES 13
StephenW
23-Emerald II
(To:mn1)
When you save the model, it is saving it as a Creo Parametric part model (.prt file). It is not saving it back to the step model.
mn1
(To:StephenW)
is it possible to save it as a step model?
and how do i save it as a prt file? i can not select this file format
BenLoosli
23-Emerald II
(To:mn1)
Use File-Save As and then select STEP.
mn1
(To:BenLoosli)
Is it possible to save just the cutted view?
Dale_Rosema
(To:mn1)
Are you extruding a cut or just showing a section view?
StephenW
23-Emerald II
(To:mn1)
Are you using Extrude to cut the model or are you just creating a cross section?
If you create an extrude cut and then save the model (as a part file or as a step file) it should save the cut.
If you are just creating a cross-section, then there is no real cut, it's only a visual.
Either we aren't understanding what you are doing or??
After you save, are you sure you are not re-opening the same original step file?
Are you saving the models to a different folder?
mn1
(To:StephenW)
I think i just created a cross section.
How can i create a extrude cut of the part of the model?
Dale_Rosema
(To:mn1)
Just do a normal extrude, but choose the Cut.PNG Icon to remove the material.
You can save it in the part but have it suppressed.
Or do a Save-As like the suggestion.
mn1
(To:Dale_Rosema)
Where fo I find this symbol?
Dale_Rosema
(To:mn1)
mn1
(To:Dale_Rosema)
Now i found everything. Thanks for help.
StephenW
23-Emerald II
(To:mn1)
Just save and it will save as a PRT model.
Use File - save as - and select step as the type to re-save as a step file
mn1
(To:StephenW)
in picture 1 you can see my model part. Then I addes a cut so it looks like picture 2. This part is what i want to save. If i use file save as and save it as a stept datei i looks like the first picture if if i oben ist again.
